A couple years ago, I bought a place out of foreclosure with a pool that was neglected for years... when I bought it, the pool was a total swamp, with frogs, tadpoles, and lots of other stuff growing in it, worse then anything I've seen. I knew you weren't supposed to drain the pool as with the inground concrete plaster pools they can pop out of the ground, and I wanted to get it cleaned up ASAP, so I went over there right after I got it at auction, before it had power or anything, and figured i should start shocking the pool as it probably wasn't going to be a fast process killing everything in it and getting it cleaned up, so I wanted the chemicals to start working. There was no testing the water with how dirty it was, so I threw in a bunch of tri-chlor tablets in, and then went the next day and bought a 100 lb bucket of cal hypo to start shocking with that (while it still didn't have power, thus no circulation or filters yet) and also used a few algaecides (for black algae and mustard algae). After a week or so I got the pump running, replaced the filter with a DE one, etc... And after probably a month or 2 after the filter was going, the pool was cleaned up, minus very severe staining.
I kept trying to keep it shocked and brushing the walls (with both wire brush and nylon) twice a day for a few months, and it didn't help. Actually, the stains did disappear in certain areas: the exact spots where I originally through the tri-chlor tablets, the marcite actually completely cleaned up and looks new again, but everywhere else it looks pretty bad. I tried taking the same tablets that appeared to clear it up in a few spots around the pool and rubbed them on the other surfaces, no luck. I've left large amounts of cal hypo granules on them, no fading, nothing. I tried repeating that task of leaving a tablet on other spots, and that didn't fade it either.
I got fustrated, and my problems were now limited to an appearance one, so I figured I'd just leave it and see if the sun would fade it, but a couple years later, it hasn't.
The pool water is crystal clear and has been so for a long time now. The pool seems to be very prone to algae (mustard and black) if I ever let the chlorine levels get low, much faster then any pool I've ever had before, but as long as I keep the FC up, it doesn't show at all, and on the overnight chlorine test, it uses almost nothing. The only other problem of note is this pool seems to get black water rings on the tile much faster then any other pool I have and they don't come off with the nylon brush, but they do come off with a magic eraser really easy, but start to reappear after only a week or 2.
I haven't tried any of the stain remover products other then pumice stones which also did nothing. What would you all recommend or is the pool stained so long/badly that it will be like that forever?
