Struggling to Clean Fine Dirt/Sand from Pool Floor – Better Options?
rajthepilot
Active member
Jul 13, 2022
31
Indianapolis, Indiana, USA
Hi folks,
I’ve been relying on my Polaris P945 robot cleaner, but even with the fine mesh filter canister (Polaris R0517800), I find that it doesn’t pick up all the fine sand/dirt. It feels like the robot stirs up the debris, and it just resettles later in the evening.
I don’t have a vacuum-to-waste setup from the skimmer—everything runs through the cartridge filter, which seems to let some of that fine dirt return to the pool.
I’m looking for a better solution to actually remove the fine dirt instead of just recirculating it. Ideally something that:
  • Sucks out dirt and discharges it outside the pool (even if it removes water)
  • Doesn't rely on the return line and cartridge filter
  • Could be manual or automatic
Any recommendations for equipment or techniques that work well for this kind of debris?
Thanks!
The Polaris P945 is a corded robot. What type of vacuum was built with the pool? Did it have a suction side or pressure side cleaner system or was it set up to use a robot from day 1?
You can add a waste line by modifying the plumbing between the pump and the filter to have a valve and Tee that becomes your waste line. Then use a manual vacuum connected to your skimmer to vacuum to waste.
