Greetings!
I have had areas of what appears to be mustard algae on the north and south walls of my pool for a while. Brushing and vacuuming seemed to make no difference, so I decided to do a SLAM and then go to MA level after completing that.
I bought a TF-Pro test kit, made recommended adjustments per PoolMath, then got the PH to 7.2 before starting. I took the pool lights out and placed them on towels on the deck and brushed the niches. The SLAM took about 6 days with a short interruption from the “almost” tropical storm that dumped 9 inches of rain on us. Yesterday morning we passed the OCLT, had 0 CC and clear water (it was clear when started, too). For the most part getting and keeping FC levels seemed straightforward and expected.
I started adding the amount of LC recommended by PoolMath to get to the mustard algae level yesterday and it took most of the day of testing and adding more and more before it reached the level I needed it to be. I have read that algae and other contaminates in the water can quickly use up the FC during a normal SLAM and although I had to keep adding chlorine to maintain the shock level I didn’t have trouble getting to the level initially. If you look at my PoolMath logs, you can see that I’ve had trouble getting to and maintaining the mustard algae level. My question is: is that typical? It made me wonder if the jugs of LC I just got refilled on Friday from the pool store were bottom of the tank or somehow comprised. Should I get more LC and continue to an extra day to see if I can maintain the correct level for MA?
