Hi,
hope everyone enjoy the long weekend.
Recently my 2-speed pump is very slow to prime under low-speed. sometimes I have to turn on high-speed for priming, then switch to low speed after priming.
I lubed the o-ring in basket, but nothing much changed.
Later I opened diverted valve but couldn't locate the o-ring(now I knew!). Worse, I made a mistake using drill when putting screws back, which broke the valve like below.
Question:
- can I fix this using some crazy glue?
- if valve has to be replaced, there is no much room for coupling etc. please refer to the dimension. Any option I can choose for such tight room?
Any advice is greatly appreciated!
Question:
