TFP Experts, need some help, please.
Situation:
Trying to sell my house and have a pesky yellow stain that is not coming out at deep end of pool (not helping).
Have brushed every day for last two weeks since pool water has been clear, no improvement.
Context:
Pool was closed for 2 years and had took almost 3 weeks to remove all organically and clarify water.
I have had a similar situation in the past on the shallow end of the pool because I have a heat pump and had metal residue I was able to remove with ascorbic acid.
I am not sure however if this stain is from 2 years of organics sitting at the bottom of the pool or a stain due to metal from the heat pump.
Current Chemistry:
- Water clarity is perfect
- Chlorine 10+ PPM (my pool guy added way too much shock about 2 weeks ago, still waiting for it to lower) but zero combined chlorine
- Alkalinity - 80
- PH - 7.2
- CYA - <40
- Phosphates - 1200
Advice Needed:
- Need help with a strategy. I understand this could be either a metal or organic stain, the latter less likely due to super high chlorine levels and very clear water.
- I understand I probably need to bring down my chlorine level, reduce phosphates and/or add chemicals (either metal remover or algicide). Just need help with order of operations here and what to try first.
- Metal stain? Algae?
- How can I optimize my pool chemistry to help remove the stain prior to adding more expensive chemicals?
Thanks in advance!!
Situation:
Context:
Current Chemistry:
- Alkalinity - 80
- PH - 7.2
- CYA - <40
- Phosphates - 1200
Advice Needed:
Thanks in advance!!
