Hey all, been a long time reading and learner from this community. Thank you for all the years of past knowledge and help!
Here's my issue. I have a 25,000 gallon pool that had a Aqua Rite system with a t-15 that worked perfectly for 5 years. Three weeks ago, it started read low salt (right after hurricane Irma) and we had lots of rain so I started putting in salt. Still low, so more salt and so on until I now have over 5000ppm (according to the pool store in town). Since it was still reading low salt, I bit the bullet and got a new Hayward t-15. Still reads low salt and won't generate.
So, I bit the smaller bullet of buying a new board. Installed it today.... still reading low salt and won't generate. Soooo..... what's up? Is the local pool store wrongly calculating my salt level? Is one of the new components I just bought bad? Is the salt at 5000ppm so high that it's causing the cell to read low?
Both the old and new board and both the old and new cell give me the same results.
I've tried the recalculating procedure and the highest it will read on the instantaneous salt reading is 2400 so that won't help me get the salt into a position where it will generate.
So, bad transformer?
When it's generating (for the few min after I first turn it on) voltage is 26.2 and amps are 4.62 which are in the acceptable range....
I'm totally baffled by this issue. Any help would be greatly appreciated. Thank you so much!!!
