- Mar 1, 2013
- 107
- Jandy Aquapure 1400
I read the resent article about storm readiness. The article mentions opening the spigot between the filter and the pump to help drain down the pool from significant rainfall. The only drain I have is the tail pipe that comes off the bottom of my Jandy cartridge filter housing. Is it safe to open that valve while the pump is running to help drain down some water? Of course I’d monitor pool water levels. I don’t have an overflow drain so if this would not work I’d have to use a submersible pump and garden hose to try and pump water out.
Thank you.
Thank you.
