Storing bromine
snuggler
Active member
Dec 6, 2021
31
Newark, New Jersey
I have an inground pool and a separate above ground (but nested in a deck) spa. I use bromine to sanitize the spa, but chlorine for the pool.
I have read about how to store certain pool chemicals separately, but can't find anything online about storing bromine. I will of course read the back of the containers as well, but from your knowledge, do I need to take special precautions for storing bromine, in the same way I need to take special precautions to keep chlorine away from anything else, trichlor away from anything else, and muriatic acid outside and away from anything else?
I cant tell you I've ever read problems with bromine storage? What I am uncomfortable with on my hot tub was the kids going back and forth from pool to hot tub. I didn't want my pool to be exposed to bromine as it traveled on wet suits/kids. Once bromine got high enough in the pool water the pool would then be a bromine pool. Eeeeck! No Bueno!!
So do be careful, is all I'm trying to say. Keep those waters separate. :)
Consider using chlorine in the spa too instead of bromine.
The two products we never want near each other are chlorine and muriatic acid. Great potential for problems!
Maddie :flower:
