If you are draining below the skimmer you can set it to waste and it bypasses your sand filter - you are essentially performing a long back wash which won't hurt just takes longer
Thanks for the quick response. I have yet to need to backwash my system (this is my first time opening a pool). By me draining the pool through setting the lever to backwash, isn't that theoretically doing the same thing as a normal backwash? Should I be setting the lever to something else to drain the pool?
Hi, I misunderstood your post. If I drain the pool instead using the backwash functionality of my DE filter, - I took it as instead of...
If you are backwashing to drain, then yes. You will need to replace DE.
Sorry for the confusion
If you plugged in the numbers correctly, it sounds like the chlorine is being consumed quickly by organics in the water. I suggest you slam the pool (bring to shock level and maintain at shock level) this will kill the organics that are consuming your chlorine so quickly.
Bring CL to shock and maintain, per the CL/CYA chart: http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
Details on SLAMing: http://www.troublefreepool.com/content/125-slam-shock-level-and-maintain-shockingl
You have passed the 3 criteria you can let you CL level drift to normal levels:
You are done when:
CC is 0.5 or lower;
You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
And the water is clear.
When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
Make sure that your pool never gets below the CL maintain level. To keep from getting below the recommended level, I dose my pool so that FC is at least 3+ higher than the recommended level of my CYA.
is it possible you are wildly underestimating the size of your pool?
I started the SLAM process, according to PoolMath, to go from 0.5 to 14ppm FC I needed to add 3 121oz jugs of bleach. I did this, checked the FC an hour later, it's at 7ppm. I'm at a loss for what to do. I'll check it again in a couple hours.......
Ok, I'm having a slight problem/confusion with FC. Based on yesterdays results of 0.4ppm, I wanted to raise to 5ppm and PoolMath is having me add 1 jug of 8.25% bleach. I did that last night, tested an hour later, and was still at 0.4ppm.
This morning I tested and got 0.2ppm of FC. Again, according to PoolMath, 1 121oz jug of bleach. I added the jug, waited about an hour. Just re-tested and I was at 2ppm FC.
What should I do at this point? The numbers aren't correlating to what PoolMath is telling me to do...
