- Mar 10, 2018
- 52
- Plaster
- Jandy Aquapure 1400
I've been running salt water pool through winter with just pool service when I noticed a little green tinge to the water. Tested Chlorine <1. No notice from service but they added 1 bag salt. I added liquid chlorine and then SWCG boost with bubbles seen, but sometime in following week saw a Jandy General fault HIGH SALT, chlorine less than 1 and no bubbles in generator. Service added salt (maybe chlorine tabs?). Jandy says Salt 4400.
SWCG looks like this after 5 hours in vinegar (initially completely plugged).
This stuff is dense on top even after vinegar so that wooden probes did nothing. Metal picks able to expose 15-20% of channels so SWCG produces some chlorine. I will run chemistries and report, and I will admit to not paying attention over winter, but in the short term
1) should I just retry vinegar, maybe 10% if I can find it? If it softens up I will use wood to force deposits out.
2) Isn't reversing polarity supposed to take care of this?
David - Dallas
David - Dallas
