I went ahead and bought the stenner pump hoping that our local pool builder would be able to install it, and I was told it was too much of a liability since it's set up on a timer and not automation. I was also told that it would have to be installed too close to the Triclor feeder and would cause a chemical reaction. My thought would be to install it just after the heater before it gets to the Trichlor feeder which should be enough water to dilute before it hits the Trichlor. Can someone with experience in this confirm my decision? The Red arrows in the pictures are possible choices for injection locations, but I think just after the heater would be best.
This is a newly installed (DEC-2022) in-ground pool that is 8000 gallons. Already had to drain once due to CYA levels getting too high and I want to use liquid chlorine as my main source.
