I am looking to move into the Stenner world and leave the heinous pucks behind forever!
I currently have an EasyTouch PSL4 (don’t shoot me, it has served me well thus far) with a Pentair VSF pump, Pentair UltraTemp heat pump and Ozone generator (wiredto come on with the pump).
My pool is 17,000 gallons. I’m planning on installing a Stenner 15gal tank and I’m unsure which pump to purchase.
I would like to wire the pump into an available Aux port in EasyTouch so that it will come on only when the pump is running. I would like the ability to program the Stenner pump on a separate schedule, allowing it to be adjusted adhoc.
Here is where I could use your help:
1.) Stenner pump model number suggestion (based on utilizing my EasyTouch as the timer)
2.) Wiring diagram/instructions for installing Stenner pump into EasyTouch - I would for it to only run when the pool pump is on and the timer schedule is activated.
Thank you!
Brandon
Thank you!
Brandon
