I was about to consider pulling the trigger on a salt water chlorinator when I started reading this forum about a Stenner pump and barrel. Now I'm pretty much 100% onboard with it but I need to figure out which ones to get..
I want to do a dual stenner setup (one for chlorine and one for muratic acid), but I'm going to lean towards just a single setup for Chlorine.
Thanks.
- For Chlorine, is a 15 or 30 gallon barrel needed? I'm guessing 15 atm for if I get it working well I can always swap it over to be the muratic acid barrel. The "barrel" will be in the pool shed.
- My pool setup has no wireless automation, so which pump has a viable timer, either manual or automated.
- Do they sell complete kits of these and where could they be found.
- The feed line into the pool.. is there a minimum/maximum distance it can be? The run from the location I intend to put the barrel/pump from the feed line is about 7 feet.
- Does the 25psi or the 100psi matter (I'd probably go with 25psi as I don't think I would need that much pressure to move chlorine)
Thanks.
