- Nov 12, 2017
- 12,657
- Plaster
- Pentair Intellichlor IC-40
You might have read that last post before I edited it. Give it another read, please.
FC 4
Pool looks fantastic!
No scratch that. Where did you get those numbers?
If the SWG is running, and you have CYA 60, then your target FC is 4. If you think you have CYA 80, then your FC target is 6.
But if you haven't turned the SWG on yet, then CYA 60 would be FC 7-9.
Here's the chart you should be using:
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.www.troublefreepool.com
17 celcius thats scary, i told the kids today its ready, water balanced, swg running, heater on, i think in morning it will be at my target of 28 so its time.....its been about 6 months and a lot of work getting it to this stage,Nice Pool!
My pool cya is at 60 now which is fine for this time of year. I'm only losing about 0.2 to 0.3 with a clean pool.
My kids have already had two swims in our pool at 17-18c day water. 26deg is like a bath here.
Jump in and enjoy.
OK, well 50 isn't on the SWG chart, and 60 isn't recommended. Use FC 5 and give the CYA a few more days. If it never gets any higher, add more CYA to get to CYA 70, then wait a week. After that, you can decide to go to CYA 80 or just leave it at 70. I run 70, and never let my FC go below 5. I'll run it up to 6 or 7. I pretend the minimum FC numbers don't exist, and use the target numbers for my minimum. That gives me a little buffer if something whacks my FC, like a bunch of kids, or a hot day or a dead animal.SWG is running, and i am using the chart, and my test on cya gave 60 or possibly 50, as said the dot at 60 was extremely faint but i could barely just see it with a stare, but at 50 its defiantly gone , so its a toss up between 50 or 60, i have not got 80 but with the 2.8 kilos of stabilizer it calculates to 80, but test is showing 60/50
at this point i am running swg at night 5 hours at 50% just waiting to see how that effects FC
Sorry for confusion i do have the chart, but used my phone today and pool math, i inputed cya 60, with my current FC 5.8, and pool math says target FC 4, i see on chart 60 is not recommended so i will add a bit more stabilizer to get it to 70, its been about 2 weeks since i last added stabilzerOK, well 50 isn't on the SWG chart,
Pool looks GREAT! Amazing how similar mine looks to the pools in the southern hemisphere where the water goes down the skimmer the other way... 🌪overwhelm me its all good more the better.... thanks for the ideas here, i am onto it, i got the cya test today and tried a few times to to be sure, i got 60 very very faint dot i mean i had to stare and really look hard to see a faint spot but it was like 90% gone.....went to 50 and dot is gone, but really 60 was so close hard to tell, thing is i know i put 2.8kg of stabilizer in so it should be 80, so makes me think its closer to 60 than 50,
so i see 60 needs 4 FC or 50 needs 3 FC, what would u all do , go with its pretty much gone at 60 and do 4 FC, or go with defiantly gone at 50 and do 3 FC , ?
attached a pic of pool its almost finished got to do a deck at 1 end but main area is done, water looking crystal clear thanks to all the help from you guys out there, put the heater on yesterday and its already up to 26 Celsius / 79 F first swim is coming up on the next sunny day, kids on holidays for 2 weeks
and will get the swg sorted soon....
yep i know i am doing my own overwhelming its the perfectionist in me, anyway your point on the " optical delusion" i think that's where i was at 60 cya, i had to was stare so hard top see a dot i think i did see it, but really it was so so faintyou will see one just from the optical delusion created by the rim of the tube.
Brett sent a new CYA-standard that you tested at 60ppm
hi, i was thinking just pass on the standard, as really it my pool water i need to know what level it is, i realize its to show me what 50 looks like but i get 60 with the standard thats outside under sun,lighting conditions that show the standards as close as possible to 50ppm
