Hello!
Our new pool is filling up right now! I was just wondering.. how do I start with the chemicals? Our pool will be SWG and now I just need to know how much chemicals I need to add. Should I test the water once there is only salt in the pool and put the info into the pool calculator for the amounts of chemicals I need to add or should I add all the chemicals first? I'm a bit confused and I've read and looked at almost all of the pool school tabs. Just to confirm, I'm going to list the different chemicals to have on hand. Please let me know if I have something off. Thanks!
FC-raise with salt (bleach or chlorine for other pools)
PH- lower with muriatic acid, raise with borax, etc
TA- raise with a baking soda
CH- raise with calcium chloride
CVA- raise with cyanuric acid
Borate- raise with boric acid, etc
oh and another question. If I add a certain chemical will it raise/lower or change another?
