Starting in 2 weeks with fresh water
Aug 31, 2018
49
NJ
starting a 23k pool with fresh liner and water. will be filling from the hose, so did a water test with my new kit and here are the results. just want to make sure I am getting it right:
PH is 7.4 this is OK
FC is 0 (ofcourse) . Using pool math app, i need to add just 1 Gallon on chlorine 16%.. is this correct ?
Salt is 200ppm. need to add 600lbs to being it to 3000ppm... sounds right.
CYA is also zero, i've ordered 10lbs of dry CYA and realized i'll need to add 4-5 more lbs
TA is 50 (will leave it for now)
CH is 50 i guess this is OK
anything else i will need to add or think about ?
Sounds pretty good. I'd suggest only adding 3/4 of the salt and CYA and letting that mix in well then wait a day and retest. You don't want to overshoot it if you can help it.
Also- keep your SWG *off* when adding all that. Don't turn it on for a day after everything is dissolved and well mixed. Use Liquid Chlorine until then and then whenever you turn on the SWG let it maintain your FC.
Maddie :flower:
