Good day! After a few months of trouble-free heating, yesterday my heater shut off before the preset temperature. (STARITE MAXETHERM 333NA.) Fenwal showed 1 blinking light (air fault) and the control board had the "service heater" light illuminated.
I shut power down for 5 minutes and restarted and observed a normal startup sequence but the blower motor didn't start. I disconnected the blower motor harness and restarted and observed 120v from the blk wire pin to ground. I reconnected the harness and restarted again and the blower energized, but the service heater light was still illuminated and the unit wouldn't fire. I restarted multiple times since and neither the blower motor nor the fenwal air fault light have energized again.
I was certain that I was dealing with a bad blower motor but when back probing the blower motor harness, I no longer see 120v after multiple start attempts so now I'm thinking this may be in the control.
I have good water flow, but jumpered the flow switch just in case and no change. I don't think that there is anything else that will prevent the blower from energizing besides a bad motor or a control failure, but wanted to double check with the experts. Thanks fellas.
