OK so just ran my numbers with my t 100 and starting to get it down back. Was low on cya fixed that, low on chlorine fixed that, ph fixed that. So I've started to learn how to adjust. This is first time with 2 things I'm unsure of. TA and CH...... Correct me if I'm wrong I don't have to worry about Ch at all correct? Being a vinyl pool? Other then then these numbers my Fc was a little low and I adjusted. Never adjusted Ta.
My numbers are
Fc 4
Cc0
Tc4
Ph 7.4
Ta 80
Ch 125
Cya 40
Soni added 3 cups of bleach according to pool math to bump my Fc to 6 which will be right in middle. Now I wonder if I should adjust Ch or Ta. Only 2 things I have never adjusted. I see Ta is baking soda. Is that just normal baking soda? And do I do like the other just disolvw in a bucket then dump in?
Thank you!
My numbers are
Fc 4
Cc0
Tc4
Ph 7.4
Ta 80
Ch 125
Cya 40
Thank you!
