I see you’re logging your additions but not your test results which makes it hard to see your fc demand without alot of calculation.
Upon your next test try this
Lets also be certain of your cya so you know you’re using the correct fc level.
If the dot “disappears” between 2 lines round up. So anywhere between 50 & 60 counts as 60.
Doing the test in bright light is best, outdoors on a sunny day is preferable.
Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more…
www.troublefreepool.com
Usually adding de will increase pressure fairly quickly in a cloudy pool.
You want to backwash when pressure rises 25% over the clean pressure you had after the de was added.
It goes like this—>
Backwash, rinse, record clean pressure, add de (mixed with water) a cup or less at a time until pressure rises by 1psi, backwash when pressure rises 25% over that psi. This removes the de., rinse.
Repeat the process again if needed.
If the pressure isn’t rising you may have a faulty gauge or have gunky/channeled sand & need to do a deep clean.
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.
www.google.com
This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are...
www.google.com
