We have had some staining develop on our old gunite pool and I don't know where they are coming from, but would like to get rid of them if possible. We purchased an older home with an older pool on which leaks have been repaired as you can see the "stripes" on the bottom from the newer plaster - it's clean! The original plaster is staining a brown color. It's not organic leaf stains as I know what those look like and I can clean those fairly easily. However, these stains don't come off when brushing. Is there anything I can do to return our gunite pool to a clean white color? Below are my readings taken this morning. Thanks for any suggestions!
Ph: 8.2 (added muriatic acid as recommended in pool math caluclator)
CYA: 40
CL: 1.5 (added liquid bleach per pool math rec to get it to 6ppm)
TA: 80ppm - have not added baking soda yet
CH: 250ppm
CYA: 40
CH: 250ppm
