The staining didn’t appear immediately. The pool builder treated it as iron, since it has a slight yellow tint around it, but it appeared around a month after being filled. Nothing really seems to lighten it, and I am now wondering if it is from when the pool was filled. Check out the hose position in the photo, the stain fans out toward the drain. The photos are from different angle, the photo of the stain is looking down from deep end, and the one with hose is looking from shallow end toward deep end.
Is this likely? With the stain not showing right away? It also might be worth noting that this area where the hose is, was wet almost constantly during plaster install. They had a pump in this area to control water. Although it was pretty dry the day they polished/filled. What effect would this have on the plaster here? Plaster in this case is hydrazzo.
