I just built my pool and have had water in it a couple of weeks. The water was clear up until 2 days ago. It started to get a little hazy and then after a really hot day it turned greenish and my steps are stained from the water line down.
I am running tricolor tabs in the aqua genie chlorine feeders at .5 ppm and had (until reading here) a blue pool rx ball.
My PH and CH were tanked. I've brought my numbers up over the last couple of days to this...
FAS DPD 8
PH 8
TA 50
CH 150
CYA 30
I've noticed the recommended numbers in the Taylor kit don't quite jive with the Pool Calculator number. Should I set the pool calculator to reflect the Taylor numbers?
FAS DPD 8
PH 8
TA 50
CH 150
CYA 30
