Hi all-- our ground is leveled (we hope... contractors said it is but the water will tell the truth!) and we're getting ready to assemble a rectangular Intex 9' x 18' AGP. The ground was dug down to level and topped with a thin skim of sand (super rocky soil).
For under the pool we'll have:
My questions:
- A tarp (a recycled billboard vinyl-- we love these as tarps)
- 1" foam boards
- pressure-treated (ground contact) 2x12s for under each leg
- we also have the tarp that comes with the pool, but that seems thin and pretty useless
My questions:
- If we cut through the foam to put the boards on the ground, the top surface of the wood will be ~1/2" higher than the foam. Is that a problem? Does Intex expect the wood to be buried in the ground, or placed on the ground? I see a lot of pics online like this, where the wood is simply on the ground, but a lot of folks on this forum talk about making it flush.
- Should we put the foam under the tarp or the tarp under foam? The foam is more slippery when wet, but the tarp (black) will be hotter on feet (will look nicer than taped pink foam, though). Both will cause ponding of water. Are there other considerations here?
