The unit is 13 yo. (cartridge) I've replaced the big o-ring twice, well lubed it, scrubbed each hold-down with scotch-brite on the filter and the clamp things, and then sprayed with silicone to allow them to slip forward for clamping action and still get leaks in various places. I have a special plier tool that allows me to turn the spinners as hard as I want (any more and I think they would crack). I've scotch-brited the grooves where the big oring goes too. I'm completely baffled. I've taken it apart several times when cleaning and each time, I get more meticulous and still have a leak at one spot. Could the rectangular clamp things spread a bit from overtightening in the past so I should try to replace a few? I can't believe the big drum itself is the problem. It's not a crack because I've looked, and the leaks happen at different places.
Ideas please!?
I just checked. One clamp is $79!! A new unit is over $1K.
Ideas please!?
