Since I don’t know what you are doing it is hard to say.Am I doing some thing wrong becuase this new ones shows o.l
But when i put the same meter in the old sfs it gives the reading of 240That is Out of Range so either you have an open circuit or your meter isn't being used correctly. There are sometimes two possible places to insert your red lead into the meter.
240 what?But when I put the same meter in the old sfs it gives the reading of 240
Let me make a video and share it here240 what?
Can you show the meter?
The sensor should be reading 3.8 Mega Ohms at 77 degrees Fahrenheit.
Can your meter read in the megaohm range?
Is the meter autoranging?
On the multimeter I had horseshoe icon selectedYou can remove the Test Lead Shields to get better contact with the test terminals.
Was the meter set to Continuity or Resistance?
What is the Resistance test range?
What is the meter model number?
It's a dial i can rotate the dialerDid you need to press Select to change from continuity to resistance?
Let me try with out the shield
