I need to remove the pump's impeller to replace bearing but it won't come off!
It does not have a screw in the middle. I have checked, there no screw hidden under any cover in the centre. With the motor drive shaft impeded the impeller should screw off anti-clockwise, right?
But the impeller just rotates on the shaft but does not 'unscrew'.
Could it be that the metal threaded insert on the impeller is loose in the impeller's plastic?
I have attached a photo.
Any help appreciated.
