Hey Folks - I have the following error code on the Fenwal, 3 flashes, "Ignition Lockout" ----> exact same as this older post. I don't see any frayed wires from critters like some of the other posts have had. I was using the heater a week ago and it worked fine and now the blower kicks on but the flame won't ignite. I've tried turning on/off many times.
The trouble shooting guide says to either replace the HSI Igniter (not sure what part that is), or the Ignition Control Module with these symptoms/conditions. Or from the above posts , could be gas pressure or the solenoid for the regulator side of the gas valve failing (or another part of gas valve I assume). Not sure how to trouble shoot these options?
Heater has worked with limited issues for 13 years. Occasionally when service light comes on, power off/on takes care of it.
Any suggestions? Do I need to call in the tech? Call the gas folks first? What order of troubleshooting?
