Sta rite heater error code
ps0303
0
In The Industry
Jul 6, 2011
4,185
FL
Moved from here.
Hello, I know this is an old thread but I am having the same problem. E06 error with service heater light on. SFS light on pc board. Replaces sensor, still not working . Checked thermal regulator, looked good. What next?
Check all of the wiring to the board to make sure nothing like a rodent has chewed it. If that looks good, then possible bad board.
JamesW
34,652
To check the stack flue temperature, press and hold the "Pool On" button for about 5 to 10 seconds.
E06 is a bad board, shorted stack flue sensor or a board not set for the correct sfs (limit type switch vs. temperature sensor).
What is the heater history? Age, recent repairs etc?
Check to see if you have a stack flue sensor or switch.
A switch is only open or closed.
A sensor checks actual stack temperature by measuring the resistance of the sensor and correlating it to temperature based on a known graph.
E06 means that the board is getting a reading of 0 ohms from the sensor.
Check the resistance, if it's 0, you have a bad sensor.
If it's high, you probably have a bad board.
The sensor should be reading 3.8 Mega Ohms at 77 degrees Fahrenheit.
Check to make sure that the board is set for the correct sensor type.
Reactions: setsailsoon
