First things first, the slide is only 1-2 years old and SR Smith already sent a repair kit (see below) but we're on our own to swap it. We just moved into the house and discovered the cracked pipe but seller led us to believe he would fix under warranty..but all he did was contact SR to get the parts mailed.
Second, I watched a couple youtube videos about removing glued PVC and it looks like a PiTA and our plumber won't repair the slide. So I guess I'm on my own so I'm hoping someone on here has had this issue and able to successfully fix it.
Third, if my guess is correct and this occurred due to the pipe freezing in the winter, how do I prevent that from happening again? I was going to ask the plumber if he could install some type of relief valve at the base of the PVC pipe to drain water but I guess that's not going to happen. What do those of you who live up north with water slides do to prevent it from freezing in the winter? Did the previous homeowner not know what they were doing or is there a proper way to get the water out of the hose with the pool valves?
FYI I need to update my info; this is a basic pool; 30,000 gallons (estimated) with a cartridge filter and those little blue valves to open/close the various pipes. I miss my spider gasket and sand filter already. :-(
Thank you guys!! Y'all have always been a great resource and I'm going to need you with this strange new pool.
Kit sent by SR Smith
