6 years ago I had a Hayward EcoStar variable speed pump (SP3400VSP) put in. Its starting to rattle and squeal and I suspect the bearings are going. From what I understand it is difficult to repair a variable speed motor and you are better off replacing the motor… and if reviews are any indication the driver won’t be far behind in which case maybe I am better off with a new pump and keep this one for spare parts?
Does anyone have a recommendation? The pump is a 2.7HP controlled with Goldline. While I don’t need the extra power day to day, I use the higher speeds for running the polaris and occasional spa. Given that I have a Goldline are there any options I should consider besides Hayward?
Thanks in advance!
Thanks in advance!
