My pool has two deck jets that shoot water returning from the pump and filter out into the pool. They are plumbed using one 1 1/2 inch pvc quarter turn valve to turn them both on or off, and then after this valve, the line splits and each is controlled separately by their own 3/4 inch pvc quarter turn valve. These are the cheap white valves with red handles used in plumbing and found at any big box home improvement store.
I want to automate these. I found some Orbit 3/4 inch sprinkler valves that I can run off a Sonoff relay really cheap. Anyone know if I can use these valves aboveground? And if they can handle the pressure? I have three regular returns that always stay open, so the individual pressure shouldn't be all that great. Any issues with using cheap sprinkler valves instead of expensive pool valves? I also found cheap brass powered valves on Amazon, but the sprinkler valves are even cheaper.
Thanks
Thanks
