TheAntebella
Active member
Mar 28, 2021
38
Durham, NC
Hello! I have three VSPs: one for my filter, one for my spa, and one for my water features. I would like to keep my VSP efficient, however anything below 2500 my spillover does not spill. Is there anyway to troubleshoot this? Thank you. Approximately 20 x 40 with raised spa.
T,
What is to troubleshoot? I suspect you have a huge spillover that requires a huge amount of water. Show us a pic of your spa and spillover.
What specific pumps do you have?
The spa spillover is normally run by the pool's main pump. While its main job is to circulate water between the filter and the pool, some of that water is also sent to the spa so that it spillover into the pool.
Show us several pics of your equipment pad and maybe we can find a way to adjust or fix your problem.
20 X 40 with elevated spa with 3-12” spillways, 3 VSPs with the exact same set up. Pool pump runs at 1,800 rpm with plenty of spill over from the spa.
Hydraulics are important to insure a good return flow.
As stated above, providing pictures also of the construction (plumbing) will also help.57852C23-77B8-4FC7-9F3F-D17B99DC0FE4.jpg
Reactions: Jimrahbe
