Spilled dichlor granules on the grass
crek31
Platinum Supporter
905
Not sure if this should be a new thread or if it is okay to add it here.
You should ask questions in your own topic, and not reuse someone else's topic. JasonLion
This evening I spilled about 1 tsp of dichlor granules on the grass right beside the pool. Had my three years olds out there with me so couldn't do much other than send them to a different part of the yard and then tried to dissolve it into the grass with the garden hose. Sprayed it about five minutes, I guess. Is there anything else I should do? What should I have done, in case it happens again?? It is in an area they will likely step on, as it is in one of the main traffic areas around the pool (between the pool and sandbox). Maybe I'm stressing over it too much, but since I came across this thread I thought I'd ask. Thanks for any info.
