My chlorine levels are sky high. And I was curious how quickly full sun + high temps can burn it off. Also does running the pump help, hinder or do nothing to speed up the process?
Thanks as usual!
Thanks as usual!
Order a TF100 test kit
The only other real option for a test kit is a Taylor K-2006-C. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. You need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
The comparison chart shows the k2006C having exactly the same as the tf100 testkit. So if ones short on FAS/DPD they both are.
Thanks MK, I will order a better one. So I am assuming that unless I can check the CYA levels there is no way to know how quickly the levels will come down? I also assume due to the test results that it’s too dangerous to swim in? Thanks again!
If you have very little CYA the FC will drop like a stone. But then you would normally never test FC in the water except for just after the addition of chlorine.
The issue is the FC/CYA ratio. That is what makes water safe or not to swim in. Minimum is 5%, maximum is 40% of CYA.
