ScottGett
5
Connecticut
Recently opened pool and spa. Each time I turn spa mode off, water gushes out of skimmer top. See attached videos. Suggestions?
Have outdoor in ground pool and separate spa that share same filter/ heater (can’t run both at same time; spa/pool does have spillover function to allow fill/ drain spa from/to pool).
Thx
Well, that is interesting. Can you post a picture of your equipment pad, especially the valves with actuators that move when you switch from pool to spa mode?
