Our pool is over 30 years old. We have noticed recently that spa water level has dropped down to about the water level of the pool over night when pump is off. We have a "never Lube' Jandy diverter valve, 3-way. Have opened the diverter valve and inspected. Check valve and O-rings were ok, no defect seen. Re-lubed all O-rings, plus the surface of check valve with spa&pool silicon lube, plus also greased the check valve from external thru grease port. Carefully reassembled everything afterward, yet the spa level still drops after several hours to the pool level. Thinking about replacing with new O-rings, and check valve, but would like to check with you all since the problems could be elsewhere (because old O-rings and check valve looked great). That was in-flo (suction side), is there connection between pool and spa on the out-flo side? Many thanks in advance.
![20230507_162527[1].jpg 20230507_162527[1].jpg](https://www.troublefreepool.com/data/attachments/257/257913-0152a0cea9b279b754ff58f3181fae08.jpg)
![20230507_162535[1].jpg 20230507_162535[1].jpg](https://www.troublefreepool.com/data/attachments/257/257914-774d38b52ab5f5dfee73779733cc78a5.jpg)
