Spa Mystery, Help!
Sharkygirl
144
Sarasota, FL
Thought my spa had a leak because I was loosing chemistry such as CH, Salt, and CYA. Had the leak detectors come out. They confirmed I had a leak. OK
Well they couldn't find the leak, they had all the jets out and then put them all back. I found a small leak at the plumbing and fixed it, sort of. When all was put back together, the blower doesn't blow air into the lines. The blower would then overheat. Had the leak guys come back, they drained half the spa, checked all the valves again. Ran the blower, it worked fine- when there wasn't water over the jets. Filled the spa, turned on the pump, turned on the blower- now I don't have bubbles again. This must be an air lock of some sort. Any ideas? As far as I know, there isn't a leak any more.
