I am having a slight issue with trying to control the temperature of my spa using my iAqualink AP. I use iAqualink to start up my spa, set the temperature and start my blower. All of this seems to work fine, except that the spa temperature according to the iAqualink Ap seems to not match up with what I programmed it to. I may for example program the spa using the iAqualink for a temp of 98, but it will often go up to 102. If I walk over to my equipment pad where the Jandy Heater is, I can look at the control panel and it will read 102. I can manually lower it to 98 and it will be reflected on the iAqualink AP.
I thought that with this automation, the iAqualink AP would be able to adjust the temp of the heater. Is this a problem with the iAqualink AP or Heater?
The iAqualink AP seems to control all the other functions as expected (pump turning on and off, ability to program and implement the programs as planned, turning on and off lights, etc.)
