My spa has a spill over waterfall that falls into the pool and for a while now it has been draining down to pool level at night when the pump is off and my auto fill has to pump in water the next day to get the pool water level back up to the correct amount. I did research and the common solution I found was to replace the backflow valve. I replaced it and the draining continued. To prevent the waste of water I closed the manual valve to the spa return while the water was drained and it stayed at that level for a couple weeks. Yesterday we had our first rain since I closed the valve and the spa has filled halfway up with water but it did not drop as I expected to overnight. This leads me to believe the water is draining from the return line that pumps water into the spa when the pump is on. As a test, I turned off the pump today and opened the spa return line and as expected the water level droppped, but before it dropped down to the pool level I closed the valve again and the water stopped draining. I'm at a loss as to what is causing the spa to drain, any guidance would be appreciated.
