- May 7, 2021
- 161
- Plaster
- Pentair Intellichlor IC-60
We found our spa/hot tub mostly drained this morning. Last night we had below freezing temperatures and the freeze protection was on. The spa spills over into the pool. The pool pump is running as normal and there's a small amount of water flowing from the returns into the spa but the water level never rises above the spa returns. I've power cycled the equipment pad and there's no error indications. The switches on the Pentair actuators are in their normal position and I haven't tried changing anything. Any suggestions? This has never happened before and I'm not sure how to proceed. Attache
d are pictures. Thanks!
