Hey all! I've done some research here and I think my problem is the spa check valve. My spa is draining down overnight. Not really below the jets, but close.
I found a Jandy flapper replacement valve, looks like just some screws to remove the cover and swap out the flapper, is it that easy? I am going to change the filter, I imagine if I do it then it will drain that line of the water so I can make the swap? Some picture below to help give more context...
