Hi All,
I’m in the middle of re-plumbing for a new pump and decided to fix a hole from an unused chlorine feed that’s been leaking since we bought the house. After I cut the pipe to replace it, I realized I don’t completely understand the flow of the water through the spa bypass.
The attached photo shows the return pipe coming from the pool heater and a diverter that lets us return to the pool or the spa. My question is, what is the purpose of the additional “bypass” loop that has the check valve and shut off valve?
I actually replaced the check valve a little over a year ago and didn’t even think to question why it’s there.
If the shut off valve is to determine how much flow goes to the spa return, couldn’t the diverter valve do the same job just partially turned?
The only scenario I could imagine this being useful for is if I wanted to close of the return completely for some reason, but i’m not sure what the reason would be?
Could this be here solely because a partial diversion of the water would result in hot water being dumped in to the pool instead of being return exclusively to the spa?
