Hi all. I had an spa air tubing line that was yanked from the piping years ago. I didn't do it. Anyhow, I am replacing the air line tubing to the air switch at the spa end. I ran a fish tape through the conduit and pulled a string through. I am going to fish the new clear vinyl tubing through and connect to the Len Gordon unit, but I had a question about how to leave that clear air tubing exposed at the equipment side - where it connects to the Len Gordon unit. I have seen pictures where the line exits the conduit and there is a wad of putty or something at the end of the pipe conduit coming out of the ground. I imagine this is to keep moisture and other things out of the conduit. Then the tube just runs naked and enters into the Len Gordon unit. Is the the way it should be installed? Should it be run in a plastic flex conduit to protect the tubing from sun exposure? No need?
Here is a pic... you can see the green string exiting the conduit stub. The Len Gordon unit is affixed to wall of house. Thanks for any info/advice!
