A few weeks ago, I noticed small bubbles in water entering the pool thru the return lines. The lid on the pump strainer basket was lubed and tight (no bubbles there), so I called my pool service guy. He found a cracked pump impeller case and replaced it, but the bubbles remained. He changed the lid and gasket on the the pump filter basket, but the bubbles remained. He suspected a leak in the skimmer, so the leak detector company checked, in stages, the line from the skimmer to the pump input and found no leaks. The tech then checked the entire pool system and found one old PVC repair that was leaking, fixed it, but the bubbles remain. There are no visible bubbles in the pump filter basket; no air escapes when I open the filter pressure relief valve. Suggestions?
Pool is a 15,000-gallon in-ground marcite with a sand filter and a Pool Pilot chlorine generator DIG-220.
Thanks for your help.
