I’ve been running into a weird problem. Every once in a while I find that there is no water moving through the skimmer. The equalizer valve is closed and the assembly is held on tightly against the o-ring by pump suction. It’s so tight I can’t be moved at all.
I have been wondering if it’s possible that at high RPMs the section from the pump is preventing the float in the equalizer assembly from floating.
Haven’t read about this before so curious if anyone has any suggestions on how to approach this.
Its an Admiral S20 skimmer and I have the correct equalizer assembly and basket and an after market pressure fit weir door.
