- Sep 1, 2011
- 545
- Plaster
- CircuPool Universal40
OK, so in the efforts to simplify my life, especially pool maintenance, I recently installed a SWCG. In order to get as much life out of it as possible, I know I have to keep my water balanced. My primary issue is pH. My fill water has an extremely high pH (8.2 or greater) with a TA of 130. every time i add fill water, it drives my pH up, so I constantly have to add acid. In order to make this part easier, I converted my Stenner from LC injection to acid injection. To hopefully make life easier (and reduce impact on the adjacent equipment) I diluted the acid from 31.45% to 6.25% by putting 3 gallons of acid in a 15 gallon tank with 12 gallons of water. Here's where I am running into the math problem. I need to know if I run my fill water for X amount of time, how long do I have to run my injection pump to cancel out the change in pH from the fill water?
So here are my given values:
Pool Volume : 21000 gallons
Target pH: 7.4
Fill water pH : 8.2
Fill water TA: 130
Fill rate: 6 gpm
Acid Concentration: 6.25% (1/5 of 31.45%)
Acid injection .007 gpm
My next step, that I can't figure out, is how much will my fill water change my pH? If I run my fill for 30 minutes, that's an addition of 180 gallons of 8.2 pH water to a pool with 21000 gallons of 7.2 pH water. How do I calculate that change in pH?
And then say I run my injection pump for 1 hour, that's an addition of 1/5 of a gallon of 31.45% acid which should lower pH by .3
Thanks for any help you can provide
Target pH: 7.4
Fill water pH : 8.2
Fill water TA: 130
Fill rate: 6 gpm
