solar temp correction value Pentair easytouch
Jan 18, 2016
157
I have an easytouch with screenlogic. My solar temp sensor is about 7-10 degrees off, likely due to the long run of the wiring. I see in screenlogic that there is a way to set a correction for the pool temp and air temp sensors. No way that I can see to do the same for the solar temp sensor. Is there a way to do it from the panel?
You can adjust the solar sensor, from the easy touch screen, go to setting then calibration. If the solar setting isn't there, hit reset and it should show up for adjustment.
