My pool is currently under construction by my licensed pool contractor and I'm looking to do the solar heating portion my self. I'm having them upgrade the control panel to a Jandy Aqualink PDA and the pump to a variable speed Jandy stealth pro series pump. From my research the Jandy is capable of controlling the solar among other things, but it is just the controller.
Aside from a 3 way valve with actuator and a temperature sensor kit, is anything else required for controls?
TEMPERATURE SENSORS:
From what I've read there are typically 2 sensors, 1 on the intake from the pool and 1just down stream of the solar collectors, is this correct? From this the controller and see if there is enough temperature rise to continue running the pump or to see if the incoming pool water has reached the set temperature.
If anyone has a decent resource online please send me that way.
I
I
