New pool owner in Florida. I am a snow bird, about 5 months in Florida. I have solar panels on the roof. Is it OK to fully bypass the panels in the summer when I am not there . Or do they need water in the hot sun?
Hi Mike welcome to TFP. It is OK to bypass the panels in the summer provided you have a release vacuum valve which would allow the panels to drain. Hope this helps
It is necessary for solar panels to drain when not in use. If they are full of water that is not circulating then the water will be superheated and the panels and/or the plumbing on the roof can fail.
