Solar panels still have pressure when actuator is closed
knew2pools
Active member
Jul 12, 2022
26
Fallbrook, CA
Hayward Aqua Rite (T-15)
Hello everyone, I'm perplexed I have a leak on one of my panels that i was going to repair. The problem it's still spraying even with actuator to the closed position and the shutoff valve going into the panels also closed. I assume its being pressured through the return side. I'm wondering if that's normal?
Does your system have a vacuum relief valve? If not, adding one would allow the water to drain out of the panels and relieve the pressure causing your squirt.
